cam belt
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=16151
Printed Date: 20 Apr 24 at 02:59 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: cam belt
Posted By: tomschute
Subject: cam belt
Date Posted: 25 May 07 at 12:15
hello,
just doing some work on my van before going off travelling and wanted to change the cam belt. Have had a good look but can't work out how to get the pulleys / fan off to get at the bottom crank pulley...
anyone done a change before that could give me some pointers?
it's a 6 cyl 2.4 diesel.
thanks all.
Posted By: mike38
Date Posted: 04 Jun 07 at 09:09
Hi Tom u need to get rid of the fan cowl and fan belt then from what i remember the viscos fan has a allen key in the center and then theres the bit that the fan is on thats held on with 4 allen bolts or torx and behind that is a big bolt that holds the bottom pully on and its torqued up to 450nm and locktighted in so u need a big bar and something to lock the bottom pully with dont try and lock the fly wheel as you could damage it or the crank i got a long bit of steel that would reach the floor and welded a bar across the end that was shaped to fit into the pulley were you bolt the fan onto which then turned to the ground and locked the pully its a bitch without the real tool
