window filler strip
Forum Name: Useful threads.
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=65845
Printed Date: 24 Nov 20 at 20:17
Topic: window filler strip
Posted By: tim
Subject: window filler strip
Date Posted: 10 Jun 11 at 15:34
baines rubber extrusion and mouldings
best place for rubber infill strip 20p per metre.Thumbs Up
lambretta lover but there is room for the t3
1981 2lt aircooled passion wagon
MAY YOU RUST IN PIECES.
http://s1085.photobucket.com/albums/j424/timwatson1/
Posted By: tim
Date Posted: 10 Jun 11 at 17:44
just thought id let you all know that standard window filler for side windows is 7mm.
Posted By: lhdwesty
Date Posted: 19 Jun 11 at 00:16
What window and what strip?
Rob.
Westy Syncro
***WANTED***
tan / beige front door cards in good condition,no top speaker holes.
Posted By: tim
Date Posted: 24 Jun 11 at 15:13
side windows and the infill strip is 7mm
Posted By: lhdwesty
Date Posted: 30 Jun 11 at 18:34
Bloody hell there's loads, do you have their part number for it?
Rob.
Westy Syncro
***WANTED***
Posted By: tim
Date Posted: 30 Jun 11 at 20:04
page 111 sf1b filler strip for crs01 i bought 7mm
Posted By: mlewi100
Date Posted: 30 Jun 11 at 22:40
Are you talking about the Westy chrome window rubber filler strip? Have you successfully fitted that particular item as it's no the same profile as the original. I bought something similar from Woolies (no not that one), but couldn't make it fit well, so bought the original strip from Heritage for £20 a window
The best things in life aren't things
Posted By: tim
Date Posted: 01 Jul 11 at 07:22
all fitted with filler strip tool which you can get from flea bay. if your not sure of sizes ask them for a couple of samples they will post them to you and you can get the right stuff mate good luck
