California and Atlantic spec.
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=8537
Printed Date: 28 Jan 21 at 11:26 Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: California and Atlantic spec.
Subject: California and Atlantic spec.
Date Posted: 26 Jul 06 at 22:33
So, seeing as I just got an Atlantic I seem to be all enthusiastic about Westies all of a sudden, having a scout about there seems to be very little info about these vans, so, lets have a brain storm and write some stuff down and stick it in the "Useful Threads" bit when it looks something like..
So, If you went to a VW dealership in Europe, and asked for a campervan/wohnmobile then you would get a Westfalia.
VW made the basic van, then it was sent to Westfalia werke to be finished off, Westfalia made the interior conversion.
Up 'til sometime in '88 you would get a "Joker" or a "Club Joker", the Joker being the normal camper, the Club Joker being the higher spec camper, the biggest noticeable difference being the double glazed windows in the rear (Identified as they are plastic and bubble out)
After '88 you would get either basic "California" or the slightly higher spec "Atlantic", Both available in pop top or high top form. Conversions after '88 all had grey interiors. You could still buy a Joker or Club Joker from other sources (Westfalia themslves?) but from VW then it was the California or Atlantic.
Both conversions are badged as "Vanagon"
Both the conversions came with the following.
As far as I know there are NO Right Hand Drive California or Atlantic models.
Onboard Gastank. fridge, 45l gas, 12v or 220v 2 burner hob, but no toaster! Rock and roll double bed. Captains chairs, both drivers and passenger seats. Power steering. Mains hook up. Split charge system. Battery charger (when connected to mains the charger will charge the auxilliary battery) Onboard 55l water supply. Oboard 20l waste water tank. Choice of petrol or Diesel engines. Choice of High top or Pop top roofs. Opening 1/4 windows. Steel wheels with wheel trims. GRP "Big" bumpers. Padded dash, Black for California, Grey for Atlantic. Revcounter. Eberspacher heater. Rectangular headlamps.
The "California" is the basic camper and sports the following...
Grey velour seats and trim.("Hellgrau" interior code - GC) GRP bumpers, but not side planks. Rear wash wipe. Heated rear screen. Available in Pastel White (R1R1), or Marsala Red (H3H3). Chrome trim around the windows. Sliding windows behind cooker, and in sliding door. Green tinted glass.
The "Atlantic" came with the following over the common items.
Double glazed "bonoflex" acrylic double glazed windows. Opening window behind cooker. Electrically operated, and heated mirrors in body colour.(hence heated rear screen switch, but no heated rear screen!) Side planks (Body kit) Different upholstery in grey/red/blue check. (code - 46) Eberspaecher heater with digital timer. Rear flap lock (where the number plate drops down, well, it's lockable) More insulation in the engine bay. Choice of Alpine white (9018), Calypso green metallic (9963) or Kirsche rot (9312) 90A alternator. Green tinted cab glass.
Options.
Alloy wheels. Air conditioning. Central locking. Colour coded bumpers and side planks. Choice of audio systems.
If you scroll down http://194.242.159.246/brick-yard/forum/forum_posts.asp?TID=8028&PN=1 - this page till the codes starting W, you will get a list of numbers, for what came with what.
If anyone can be arsed to do the California and Atlantic ones that would be good.
Eg, California pop top came with options... la di da etc..
If anyone has anything to add please do so..
Posted By: calvin
Date Posted: 26 Jul 06 at 22:53
Cool. Now there's gunna be someone as interested in finding bits for these beasties as I have been over the past 7 months!
I dont know much about the Atlantics (other than I now know yours is obviously better equipped than mine ) but i can confirm that mine is equipped (as standard, wasnt touched before my greasy mitts) as follows:
Opening window behind cooker (slider)
Petrol Eberspaecher heater with thermostatic control
Lots of insulation in the engine bay (not sure if thats more or what!)
Eis-Ex LPG jet heater system (not used mine yet)
Alternator i'll have to check on.
Curtains in grey / red (barely noticeable) check. (i guess you assumed these were present).
oh, and mine's a 1989 LHD.
So, does your water tank depth gauge work? Mine says its always full
and i cannot work out what the rod in the tank does as it seems
completely diss, yet there's no way of dismantling it..
Nice bus tho - glad to hear someone with cred giving these the
we love ours and sprogs from very small size love the trips too.
------------- Ever tried eating a clown? They taste funny.
'89 2.1 Westy California darn sarf, Sussex.
+++ Still looking for good OSR big bumper corner section PLEASE! +++
Posted By: Schimke
Date Posted: 26 Jul 06 at 23:04
Cool information, thanks.
I would bet that the opening window behind the cooker would be a welcome addition on certain days.
Date Posted: 26 Jul 06 at 23:05
I've always liked them, just never been able to afford one, since the sale of the green van then I could, as it wasn't much more, and in comparison.... I really don't see the point in buying a converted builders van for around 4-5 grand (No disrespect but Liesuredrives, Autohomes, EMC, Danbury, Devons, Vikings don't have a patch on Westies and Im not just saying that because I have one!) VW commisioned them, VW sold them, through their deealer network, they hold their prices for good reason, they are proper!
Posted By: calvin
Date Posted: 26 Jul 06 at 23:27
oh, and you can toast quite successfully:
inside on the hob,
or outside on the LPG barbeque
- did yours come with the outlet for that on the LPG tank - is that standard?
Date Posted: 27 Jul 06 at 00:13
inside on the hob, or outside on the LPG barbeque
They all have the external gas outlet, Im just on with translating the instructions into English as I have the original German booklet.
Im gunna get all the confusiong bits together so they can be downloaded, I have instructions for the control panel on the fridge already.
They all have "Eis-Ex" or De-Icer, all it is is that it's a small heating element that heats the gas when it exits the regulator to stop it turning into a liquid and letting the cooker give off 4 ft flames (as happened to us in Chamonix and minus 10 while cooking pasta in the awning
Posted By: calvin
Date Posted: 27 Jul 06 at 00:16
Baxter wrote:
...to stop it turning into a liquid and letting the cooker give off 4 ft flames... |
ooooh - now that sounds "interesting"!
I thought it might be standard fitment, hope my other points are of use.
Are your double-glazed panels glass on the inside like usual vans, or
is it a complete sealed unit (therefore lighter than glass?)?
Date Posted: 27 Jul 06 at 00:19
Fully acrylic!
Other words, plastc!
Posted By: cooky73
Date Posted: 27 Jul 06 at 13:31
mine has the non-digi eber heater & sunroof as well
does this mean we can have a "campers" section like on 80-90 now?
my depth gauge is kaput also
tell you what - you could make a killing selling them
you could also sell covers for the gas controls as well - they are a bugger to get hold of!
I have got the joker manual in English and it seems the same
get one of those toast thingys from argos - they are fantastic!
what engine is it Simon?
------------- 2003 Westy California TDi
Posted By: T2Andy
Date Posted: 27 Jul 06 at 13:40
OK mine is as per your Californina list except that is has the Diesel Eberspaecher, it has sliding windows behind the cooker and in the sliding door.
What I like about it is that all of the camping stuff works, the control panel, Eber, Water tanks etc. Fridge lights on Gas within a few seconds, all of it, that's quality for you.
The only things I need to sort on mine is the Heated Rear screen and Wiper have had the wires chopped through, either by the tailgate or someone and the Rev counter is missing the plug to connect the printed circuit.
------------- 1990 1.6TD Westy California Hightop
Posted By: malverner
Date Posted: 28 Jul 06 at 00:32
Good choice of van Simon
we've had ours over 4 years....best T3 campers
Detail wise...
Atlantics have a thicker grey carpet than Californias
Tinted glass in cab
Bog box with matching cloth
You can open the wardrope cupboard with the swivel out table in its storage place (early Westies you have to move the table to open the cupboard)
Removable popper curtains for cab/permanent curtains behind front seats
Poppers for removable tailgate mozzy net
Quality build....
Posted By: terryvanman
Date Posted: 28 Jul 06 at 08:49
Hello
I had a california,,,,it was probably one of the best in the country. Totally mint condition
I went off to the USA for a weeks holiday when i got back,,,,,,GONE,,,,,,, some lowlife had nicked it &nbs p;
I found out from a neighbour that it had been lifted up onto a low loader at 4 AM and they just drove off with it. It had a steering wheel clamp and the alarm was going as it was taken away,
these vans are so sort after and fetch high prices as spare parts in europe. Mine was one of 4 taken in the london area that week...please make sure you take full precautions.
------------- new heart...new van...new man
Posted By: David Pickles
Date Posted: 28 Jul 06 at 11:34
You could buy a right hand drive westfalia in the UK. Westfalia did make them. They were brought in by a few different companies at different times. I have the details some where including road tests.
I don't think the later Californias or Atlantics were ever made in RHD for the UK. although there was a UK agent for Westfalia called RN Engineering who would convert a van to a California with new genuine bits. I have the price list from them. So the must be some RHD Californias but not factory built.
------------- 1990 1.9td SYNCRO DOKA
1988 1.6td SYNCRO AMBULANCE
1989 2.1i LPG Camper
Date Posted: 07 Oct 06 at 18:22
terryvanman wrote:
Hello
I went off to the USA for a weeks holiday when i got back,,,,,,GONE,,,,,,, some lowlife had nicked it & ;nbs p;
That doesn't look like a California to me.
It is a US import and has different hook up etc to the European models, It also has a cab luggage rack, again as far as I know they didn't come with those.
It has electric mirrors too, again California didn't come with those, it has side marker lights... not in Europe...
That looks like aUS import Vanagon that someone has added California decals to, that van is much higher spec than a California.
Posted By: CaliforniaDream
Date Posted: 25 Apr 07 at 01:20
I think you may have missed the biggest difference and the reason Westies are often in better condition bodywise.
As I understand it, Westfalia didn't base their version on the transporter van, they based it on the Caravelle. This may not appear to make much of a difference but when you consider that all the windows were factory cut, shaped and treated plus they have sliding openers etc they are more user friendly and less prone to rot.
Martin
------------- On wings like angels whispers sweet
my heart it feels a broken beat
Touched soul and hurt lay wounded deep
Brown eyes are lost afar now sleep xxHayleyxx
Posted By: dub dub campers
Date Posted: 25 Apr 07 at 08:06
My Question is to Baxter as he seems to be the man in the know, were the extra's on the Alantic's ever fitted to the California's as i have had a couple of California's with locking rear flap, opening window behind cooker, eberspaecher heater, electris windows, Would these be factory fitted extra's or would Mr/Mrs bloggs buy a California as it was cheaper then buy the extra parts they wanted on the van and fit after market,
------------- dub dub
Stuart Roper,
Lampeter, Mid Wales
07966 270767,
dubdubcampers@aol.com
Date Posted: 25 Apr 07 at 20:18
Locking rear flap was a option on anything, not only Westies.
California's have a sliding window behind the cooker anway, the California glass is meant to be some special pilkington stuff, green tinted.
Eberspacher, funny, I see some with and some without. I presume they came without and having one was an option, as was the electronic timer thingy.
Electric windows were an option on anything.
Posted By: chickenkoop
Date Posted: 28 Apr 07 at 13:01
westy california I've got, but the heater is a Truma-e. works off the engine and lpg, these van are 19 years old and the layout is still right for today, the germans do think ahead.
------------- 98, karmann Colorado, 89, T3 westy california Brickin it in Cov.
Date Posted: 07 May 07 at 19:42
Non California and Atlantic chaff deleted to keep the thread about what the topic title was!
Any more drivvel will also get the chop.
Posted By: Stuckonthegrid
Date Posted: 15 Sep 07 at 13:30
My 89 california has double glazing and a webasto petrol heater and timer and it all looks factory fitted.
Posted By: busbuddy
Date Posted: 29 Sep 07 at 21:18
http://www.trumauk.com/uk-service/ - http://www.trumauk.com/uk-service/
------------- http://www.karmann-coachbuilts.com" rel="nofollow - Karmann
Posted By: chucklebus
Date Posted: 01 Oct 07 at 19:16
Mine is an 89 California
Has: 1600 TD engine Single Glazing Truma E1800 gas heater - no timer No battery charger - is this normal??? Lesiure battery under passenger (RH) seat Inboard water tank Underslung gas and waste tanks
