Aaz fuel pump mk1 caddy HELPPPP ðŸ˜
Category: Other VW
Forum Name: Caddy
Forum Description: Forum for Caddy specific chat.
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=93083
Printed Date: 29 Mar 24 at 12:09 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Aaz fuel pump mk1 caddy HELPPPP ðŸ˜
Posted By: Mk1Dean
Subject: Aaz fuel pump mk1 caddy HELPPPP ðŸ˜
Date Posted: 25 Oct 17 at 20:24
First post on this forum it's the one I look on mostly so thought I'd register a account..
I've got a mk1 caddy which I'm restoring from the ground up and decided to go for a aaz conversion as its nice and easy for my first conversion
After searching and searching I finally came across a complete engine for sale for only £130 which I thought was fairly cheap considering I've seen it running in the car it came from,I've had the engine for a week now and decided to actually take a look at it when I discovered the fuel pump is electronic and not mechanical,first of all I thought I'd been ripped off and the engine wasn't aaz but after looking I've seen people say they are fitted to the later engines
So basically I want to know is it possible to convert a electric pump to mechanical, I've seen a few posts saying about chopping wires etc but didn't really fully answer my question or I probably didn't understand or should I just buy a mechanical pump and I assume it's a easy swap job, I'm replacing the Cambelt anyway
Posted By: Timjburrows
Date Posted: 25 Oct 17 at 21:38
Welcome,there were no aaz engines with fly by wire pumps.what you may have is a late aaz with an immobiliser,it's possable to remove the plastic cover and connect the fuel cutoff wire directly to the stop soloniod
Posted By: Mk1Dean
Date Posted: 26 Oct 17 at 14:37
This is the pump I have
Posted By: Mk1Dean
Date Posted: 26 Oct 17 at 16:55
Just questioned the seller about it and they are now denying it was advertised as a aaz even though I have all the texts etc, shocking seeing as it came from a VW breaker
Date Posted: 26 Oct 17 at 19:19
That's a tdi or sdi pump may be possable to go landrover 200 or 300 tdi pump for non electricial alterative
Posted By: ob1
Date Posted: 27 Oct 17 at 17:04
I’ve got a pump. It’s an AAZ not the best one in the world but powered my bus for 40k miles and was going strong when I removed it. I can get delivered to your door say for £70 all inc?
Posted By: ob1
Date Posted: 27 Oct 17 at 17:05
Ah next question is is that an AAZ engine!
Posted By: Mk1Dean
Date Posted: 27 Oct 17 at 17:14
Thanks for the offer but it's not a aaz engine
The seller ( a VW breaker in holt Norfolk ) is refusing to give me a refund even though it was advertised as a aaz
Posted By: ob1
Date Posted: 27 Oct 17 at 20:17
Small claims court then. If you have a copy of the advert!
Posted By: guz
Date Posted: 28 Oct 17 at 10:14
Sell it on and mark it up to experience, you said it was cheap anyway
------------- location/moby number removed.
Posted By: Mk1Dean
Date Posted: 29 Oct 17 at 15:48
Got my money back today after threatening them with trading standards... Definitely learned my lesson on this one
