2011 T5.1 Interior Lights
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=94352
Printed Date: 19 Apr 24 at 15:51 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: 2011 T5.1 Interior Lights
Posted By: StevenMurray
Subject: 2011 T5.1 Interior Lights
Date Posted: 19 Jan 20 at 18:33
Hi All,
I've just bought a T5.1 Panel Van, and the interior lights aren't working. I've tested the bulbs and they're okay. There's 12vdc coming away from Fuse 17 in the middle of the lower fuse box on a red/black wire, but no power appearing at the white plug inside the passenger end cap of the dash on the red/black wire there.
Does anyone know where the red/black wire from the fuse goes to? I'm assuming it goes to some multi way connector for all internal lights and that there may be a disconnect causing the issue. I can see it disappearing into the loom near the scuttle when I took the dashboard pocket out, but shy of dismantling the entire dash, I'm at a loss as to what to check next?
Is it likely to cause an issue if I disconnect the 2 x large connectors on the Body Control Module for 'ringing out' purposes with a multi-meter?
Any help would be most welcome, as just now I'm puddling around in the dark (literally..)
Thanks,
Steve.
------------- 2011 VW T5.1 Transporter Duct Tape & WD40 = Man's Best Friend
Posted By: Charlie Dog
Date Posted: 21 Jan 20 at 16:46
StevenMurray wrote:
Hi All,
Does anyone know where the red/black wire from the fuse goes to? If yours is the same as mine, Fuse 7 15 Amps Multifunction control module1 (interior lamp) I'm assuming it goes to some multi way connector for all internal lights and that there may be a disconnect causing the issue. I can see it disappearing into the loom near the scuttle when I took the dashboard pocket out, but shy of dismantling the entire dash, I'm at a loss as to what to check next?
Thanks,
Steve. |
Date Posted: 21 Jan 20 at 17:14
Hi Charlie,
Is that fuse one of the ones below the Drinks holder, or are there more fuses near the BCM?
Date Posted: 21 Jan 20 at 17:39
StevenMurray wrote:
Hi Charlie,
Is that fuse one of the ones below the Drinks holder, or are there more fuses near the BCM? |
Yes Steven. https://t5-6mods.co.uk/site/wp-content/uploads/2017/05/VW-T5-2003-2014-Fuse-Boxes.pdf" rel="nofollow - https://t5-6mods.co.uk/site/wp-content/uploads/2017/05/VW-T5-2003-2014-Fuse-Boxes.pdf
Date Posted: 21 Jan 20 at 17:49
This may be of some help to you, even though it's a later T6 Steven.
https://www.youtube.com/watch?v=6QzF57MurxM" rel="nofollow - https://www.youtube.com/watch?v=6QzF57MurxM
Date Posted: 21 Jan 20 at 19:36
Unfortunately mine doesn't have a #7 Fuse in either the upper or lower fuse boxes, and doesn't have any contacts in there to accept a fuse..
Date Posted: 21 Jan 20 at 19:57
Each fuse has a couple of contacts on it's back. They are difficult to see.
If you use one of these https://www.ebay.co.uk/itm/Circuit-Tester-Cars-Automotive-Light-Probe-Voltage-Pen-Test-Tools-DC-6V-24V-12V/352760946230?_trkparms=ispr%3D1&hash=item522230de36:g:FJoAAOSwdmRdCKkk&enc=AQAEAAACQBPxNw%2BVj6nta7CKEs3N0qXAP9837677ZDqegGRXysFgezDKqHrRGxN82vGsW1cWdp7UIQzlANjGymalgjshdbv2eSqDrCowD%2FqCUZy7yZkIADUnrUrSIfj5D%2F8pDXOY%2BxZpQYfBmkI6LZRW%2BCvyqBwmT%2BVc6CvLE7jFbOku26xYf4GuQSrfTqnvazXbKv5abkWjBIrOr95FQrVbV4nKI6osPaIrZloWIkYVYcH5DTe4Hgzp1tM8crqGr8DSxT%2F%2B3AeHutAlmqKFGqHwedDG%2FDHjXeBNXHCyYwdaexnZlfonrDSXGgoPktZnd7i5k8Rk9aNAhoGxqzqaoRbxRzUGSyy7KbT4lI3LJpfy8ebSIxl3EX2SWXTZCm5NVGFC6eI6grSffAq3SVRFqyikVtpFiHw3tlUi5sCGZMyxFhpMcD8PysXl5NUncqs93BOZtC6NpdNwUraXnQw4C0DhXkhRjxEuwz7wlbdojdwAxs5NGuaC9AE0TaV7F3xq1tBMMJUrLxSjHc5KrJTkQHf1A6hbxGqp80sHCscdyJEuh76azArzK%2B7faD7pj91KklJ%2BC7tE6Xw6TptZGoTBR7bIx%2Bvsitnqx4lqY8pIQQUX4anEay7sXnqW7TVpD4kYjCphiEfIsAk6cINie6Tnzv7zm26S3L%2FgHnLXE8Sf%2FyVM7qQWZItYtiDhs3QTqt3xE%2BpdK7B08X2xUOkMw3qC7SGOe6zKI6M4m1qzV0h0HCstOfGPWmE%2FPrQGHpx7Jb66Fb5PvQXxTQ%3D%3D&checksum=3527609462304297d22935854a218e50be5b9412bf60&enc=AQAEAAACQBPxNw%2BVj6nta7CKEs3N0qXAP9837677ZDqegGRXysFgezDKqHrRGxN82vGsW1cWdp7UIQzlANjGymalgjshdbv2eSqDrCowD%2FqCUZy7yZkIADUnrUrSIfj5D%2F8pDXOY%2BxZpQYfBmkI6LZRW%2BCvyqBwmT%2BVc6CvLE7jFbOku26xYf4GuQSrfTqnvazXbKv5abkWjBIrOr95FQrVbV4nKI6osPaIrZloWIkYVYcH5DTe4Hgzp1tM8crqGr8DSxT%2F%2B3AeHutAlmqKFGqHwedDG%2FDHjXeBNXHCyYwdaexnZlfonrDSXGgoPktZnd7i5k8Rk9aNAhoGxqzqaoRbxRzUGSyy7KbT4lI3LJpfy8ebSIxl3EX2SWXTZCm5NVGFC6eI6grSffAq3SVRFqyikVtpFiHw3tlUi5sCGZMyxFhpMcD8PysXl5NUncqs93BOZtC6NpdNwUraXnQw4C0DhXkhRjxEuwz7wlbdojdwAxs5NGuaC9AE0TaV7F3xq1tBMMJUrLxSjHc5KrJTkQHf1A6hbxGqp80sHCscdyJEuh76azArzK%2B7faD7pj91KklJ%2BC7tE6Xw6TptZGoTBR7bIx%2Bvsitnqx4lqY8pIQQUX4anEay7sXnqW7TVpD4kYjCphiEfIsAk6cINie6Tnzv7zm26S3L%2FgHnLXE8Sf%2FyVM7qQWZItYtiDhs3QTqt3xE%2BpdK7B08X2xUOkMw3qC7SGOe6zKI6M4m1qzV0h0HCstOfGPWmE%2FPrQGHpx7Jb66Fb5PvQXxTQ%3D%3D&checksum=3527609462304297d22935854a218e50be5b9412bf60" rel="nofollow - https://www.ebay.co.uk/itm/Circuit-Tester-Cars-Automotive-Light-Probe-Voltage-Pen-Test-Tools-DC-6V-24V-12V/352760946230?_trkparms=ispr%3D1&hash=item522230de36:g:FJoAAOSwdmRdCKkk&enc=AQAEAAACQBPxNw%2BVj6nta7CKEs3N0qXAP9837677ZDqegGRXysFgezDKqHrRGxN82vGsW1cWdp7UIQzlANjGymalgjshdbv2eSqDrCowD%2FqCUZy7yZkIADUnrUrSIfj5D%2F8pDXOY%2BxZpQYfBmkI6LZRW%2BCvyqBwmT%2BVc6CvLE7jFbOku26xYf4GuQSrfTqnvazXbKv5abkWjBIrOr95FQrVbV4nKI6osPaIrZloWIkYVYcH5DTe4Hgzp1tM8crqGr8DSxT%2F%2B3AeHutAlmqKFGqHwedDG%2FDHjXeBNXHCyYwdaexnZlfoNrDSXGgoPktZnd7i5k8Rk9aNAhoGxqzqaoRbxRzUGSyy7KbT4lI3LJpfy8ebSIxl3EX2SWXTZCm5NVGFC6eI6grSffAq3SVRFqyikVtpFiHw3tlUi5sCGZMyxFhpMcD8PysXl5NUncqs93BOZtC6NpdNwUraXnQw4C0DhXkhRjxEuwz7wlbdojdwAxs5NGuaC9AE0TaV7F3xq1tBMMJUrLxSjHc5KrJTkQHf1A6hbxGqp80sHCscdyJEuh76azArzK%2B7faD7pj91KklJ%2BC7tE6Xw6TptZGoTBR7bIx%2Bvsitnqx4lqY8pIQQUX4anEay7sXnqW7TVpD4kYjCphiEfIsAk6cINie6Tnzv7zm26S3L%2FgHnLXE8Sf%2FyVM7qQWZItYtiDhs3QTqt3xE%2BpdK7B08X2xUOkMw3qC7SGOe6zKI6M4m1qzV0h0HCstOfGPWmE%2FPrQGHpx7Jb66Fb5PvQXxTQ%3D%3D&checksum=3527609462304297d22935854a218e50be5b9412bf60&enc=AQAEAAACQBPxNw%2BVj6nta7CKEs3N0qXAP9837677ZDqegGRXysFgezDKqHrRGxN82vGsW1cWdp7UIQzlANjGymalgjshdbv2eSqDrCowD%2FqCUZy7yZkIADUnrUrSIfj5D%2F8pDXOY%2BxZpQYfBmkI6LZRW%2BCvyqBwmT%2BVc6CvLE7jFbOku26xYf4GuQSrfTqnvazXbKv5abkWjBIrOr95FQrVbV4nKI6osPaIrZloWIkYVYcH5DTe4Hgzp1tM8crqGr8DSxT%2F%2B3AeHutAlmqKFGqHwedDG%2FDHjXeBNXHCyYwdaexnZlfoNrDSXGgoPktZnd7i5k8Rk9aNAhoGxqzqaoRbxRzUGSyy7KbT4lI3LJpfy8ebSIxl3EX2SWXTZCm5NVGFC6eI6grSffAq3SVRFqyikVtpFiHw3tlUi5sCGZMyxFhpMcD8PysXl5NUncqs93BOZtC6NpdNwUraXnQw4C0DhXkhRjxEuwz7wlbdojdwAxs5NGuaC9AE0TaV7F3xq1tBMMJUrLxSjHc5KrJTkQHf1A6hbxGqp80sHCscdyJEuh76azArzK%2B7faD7pj91KklJ%2BC7tE6Xw6TptZGoTBR7bIx%2Bvsitnqx4lqY8pIQQUX4anEay7sXnqW7TVpD4kYjCphiEfIsAk6cINie6Tnzv7zm26S3L%2FgHnLXE8Sf%2FyVM7qQWZItYtiDhs3QTqt3xE%2BpdK7B08X2xUOkMw3qC7SGOe6zKI6M4m1qzV0h0HCstOfGPWmE%2FPrQGHpx7Jb66Fb5PvQXxTQ%3D%3D&checksum=3527609462304297d22935854a218e50be5b9412bf60 you can check your fuses.
As the interior light works with the ign off: -
With the ignition off. If the fuse is live at one check point but not at the other check point then it's a dud.
Date Posted: 22 Jan 20 at 07:26
My T5 switches off the the interior lights approx 10 minutes after switching the engine off. Have you tried it with the ignition on ?
Date Posted: 22 Jan 20 at 09:26
Do your interior lights only work when the ign is on please Greg?
Date Posted: 22 Jan 20 at 10:22
Thanks guys. I've tried with the ignition on, off, engine running etc., etc.
Even sitting in it with the engine running, there's no power at the white socket on the left side of the dash or at the light itself in the roof.
It's either looking like a fault in the BCM, or a loose connection in some hidden location.
I see that some people have wired connector blocks etc. beneath the rubber mats under the front seats. Do all vans have this?
Do any of the interior lights wiring go through here?
Cheers lads for the suggestions so far. :)
Steve.
Date Posted: 22 Jan 20 at 10:49
How about running a supply from a piggyback fuse up to your interior light switch Steve.
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR4.TRC2.A0.H0.Xpiggy+back+fuse+-mini.TRS0&_nkw=piggy+back+fuse+-mini&_sacat=0" rel="nofollow - https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR4.TRC2.A0.H0.Xpiggy+back+fuse+-mini.TRS0&_nkw=piggy+back+fuse+-mini&_sacat=0
Date Posted: 22 Jan 20 at 11:40
Charlie Dog wrote:
Do your interior lights only work when the ign is on please Greg? |
I think my interior lights stay on all the time when the ignition is switched on, but I haven't actually tried it for any length of time.
When the ignition has been switched off for a while they won't switch on unless I close a door, then they stay on for about 10 minutes, then automatically turn off (if I open & close a door, they will come back on for another period).
Date Posted: 22 Jan 20 at 13:08
Date Posted: 22 Jan 20 at 17:41
The J519 (behind the dash on the passenger side) has a role in the interior lights. I think there is a fuse that is also link to to the J519 so it's vital to test each fuse with a test lamp or meter. It is best to test them in place because you may cause codes to cause confusion later.
Another oddity is that the way they work. With a permanent earth, a switched earth and a live that isn't necessarily live all the time. I'd definitely start with the other fuses and see if LED bulbs have been added.
Wash my mouth out with soap but there is an excellent description here - https://www.vwt4forum.co.uk/threads/switched-earth-in-interior-lights.1279274/
Date Posted: 22 Jan 20 at 17:50
Normal people believe that if it ain't broke, don't fix it.
Engineers believe that if it ain't broke, it ain't sufficiently complex yet.
Wash my mouth out with soap but there is an excellent description here - https://www.vwt4forum.co.uk/threads/switched-earth-in-interior-lights.1279274/ |
Date Posted: 22 Jan 20 at 19:25
Cheers, that's given me a few ideas. I've managed to find my test light so gonna have a go tomorrow night and see what I can find. :)
Date Posted: 23 Jan 20 at 13:35
From my end of the microscope that there Pandora's Box, the one T5 TDi calls J519 suffers from Premenstrual Syndrome.
Mine enjoys some mardy days.
Some days J519 flattens my battery. Some days it doesn't.
I send it to purdah by switching my interior lights off when I leave the van for more than a day.
Switching the lights on when I want them, and off again when I don't is not a big deal.
Date Posted: 23 Jan 20 at 21:03
Haha Pandora's Box! You mean the one that all the evil things came out of? Sounds about right for the J519! Or did you mean this one from 1975? Much better ;-)
https://www.youtube.com/watch?v=JInOpWL7Llo" rel="nofollow - https://www.youtube.com/watch?v=JInOpWL7Llo
Date Posted: 24 Jan 20 at 08:01
I tossed up between the Greek 'un and Room 101 T5.
In hindsight, Room 101 does the biz better.
Date Posted: 24 Jan 20 at 08:05
BTW I've been running LED interior lights in my van for over 10 years with no problems. They must be better quality than the one I put in the cargo bay of my Golf R wagon, it has started to intermittently fail after only 2 years :(
The only oddity I've noticed in the van is they give a faint glow if switched on after the "expired timer forced off thing", if switched off they are totally off (no glow at all).
Date Posted: 24 Jan 20 at 08:19
That's very interesting Greg, thanks :o)
The faint glow can only be down to electricity flow through the circuit.
If you refit tungsten bulbs I daresay you'll get a flat battery after a few days.
Date Posted: 24 Jan 20 at 08:24
That's after a few days parked up.
Date Posted: 24 Jan 20 at 17:22
Would you be happy to measure current flow through your interior leds when they are aglow Greg?
Date Posted: 25 Jan 20 at 01:11
Charlie Dog wrote:
Would you be happy to measure current flow through your interior leds when they are aglow Greg? |
To be honest, I'm not keen, as I don't want to mess with the connectors or short out the fuse (due to clumsiness).
I'm selling my van soon and I have a whole heap of other jobs to do to get it ready for sale.
The current used must be very very small, as even when fully lit LEDs don't use much. I have often left my van for weeks between uses without flattening the battery, but that is with the interior lights manually switched off.
Date Posted: 25 Jan 20 at 08:16
I don't blame you Greg :o)
Date Posted: 25 Jan 20 at 21:04
After trawling the Net.
Could be Fuse 24 in the lower array near gear doofer
https://www.drive2.com/l/468710812878373683/" rel="nofollow - https://www.drive2.com/l/468710812878373683/
