This is really frying my head now
I've replaced the egr cooler pump. The pump runs fine with the engine running and continues to run for a short time after the engine is turned off.
BUT. The code won't re set. The coil light flashes and the eml is on and its still in limp home mode.
The replacement pump is a First Line, so not cheap junk.
copy of the auto scan below. Friday,10,July,2020,09:25:40:34525 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 20.4.1.0 (x64) Data version: 20200331 DS317.0 www.Ross-Tech.com
VIN: WV1ZZZ2EZF6023526 License Plate:
Chassis Type: 2E-N/A (2E - VW Crafter Panel Van (LT3 / 2006 > 2016)) Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3 B0 B1 B2 B3 B4 B5 B6 C1 VIN: WV1ZZZ2EZF6023526 ------------------------------------------------------------------------------- Address 01: Engine (J623-CKTB) Labels:. 03L-906-012-CKT.clb Part No SW: 03L 906 012 J HW: 03L 906 012 A Component: R4 2.0l TDI H26 9977 Revision: 72H26--- Serial number: VWXDZ0N1047149 Coding: 0119401020440D080000 Shop #: WSC 131071 1023 2097151 ASAM Dataset: EV_ECM20TDI01103L906012J 002016 ROD: EV_ECM20TDI01103L906012BS_002.rod VCID: 2B52B95E4283EDDE8E-807E
1 Fault Found: 4875 - Coolant Pump 2 P261A 00 [167] - Open circuit MIL ON - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 87454 km Date: 2047.15.31 Time: 31:63:63
Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 25 °C Intake air temperature: 14 °C Ambient air pressure: 990 mbar Voltage terminal 30: 12.300 V Unlearning counter according OBD: 40 Coolant temperature at radiator outlet: actual value: 16.4 °C exh.gas recirc.: shut-off conditions-Bits 0-7: 0 exh.gas recirc.: shut-off conditions-Bits 0-7: 0 exh.gas recirc.: shut-off conditions-Bits 0-7: 0 exh.gas recirc.: shut-off conditions-Bits 0-7: 5 EGR cooling function: status-Bits 0-7: 4 exh.gas recirc. (EGR) cooler pump: specified value: 0.00 % EGR Vacuum Regulator Solen.val.: activation: 100.00 % Exh.gas temp.sen 1: 56.8 °C
Readiness: 0 0 0 0 1
------------------------------------------------------------------------------- Address 93: LT3 Immo Labels: 2E0-905-865-93.clb Part No SW: 2E0 905 843 C HW: 906 900 590 2 Component: IMMO 1231 1322 Revision: 00231000 Serial number: VWXDZ0N1047149 Shop #: WSC 00000 000 00000 VCID: 275A456E966BC9BE6A-8072
1 Fault Found: 01176 - Key 008 - Implausible Signal - Intermittent
------------------------------------------------------------------------------- Address 94: LT3 Airbag Part No HW: 9069005701 Shop #: WSC 00117 555 00000 ASAM Dataset: 3 3332 ROD: CRFT_AB_3_3331.rod (*) VCID: 55A63FA634878B2E08-8000
No fault code found.
------------------------------------------------------------------------------- Address 96: LT3 Instruments Part No SW: 9069026601 HW: 9069014501 Shop #: WSC 00000 000 00000 ASAM Dataset: 32 1056 ROD: CRFT_KOMBI_32_1056.rod VCID: 071A25EEBEABE9BE4A-8052
1 Fault Found: 9100 - Drivetrain CAN: No communication Test Complete - Stored
------------------------------------------------------------------------------- Address 99: LT3 Ign. Switch Part No HW: 9069005902 Shop #: WSC 00000 000 00000 ASAM Dataset: 67 259 ROD: CRFT_EZS_67_259.rod VCID: 55A63FA634878B2E08-8000
------------------------------------------------------------------------------- Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb Part No SW: 2E0 905 843 C HW: 906 900 590 2 Component: HF-FFB 1231 1322 Revision: 00231000 Serial number: 12345678901234 Shop #: WSC 00000 000 00000 VCID: 275A456E966BC9BE6A-8072
1 Fault Found: 00171 - Key 1 not learned 000 - - - Intermittent
------------------------------------------------------------------------------- Address 9B: LT3 Driver Door Part No HW: 9069000501 Shop #: WSC 00000 000 00000 ASAM Dataset: 33 263 ROD: CRFT_FTUHR_33_263.rod VCID: 55A63FA634878B2E08-8000
------------------------------------------------------------------------------- Address B4: LT3 Central Elec. Part No SW: 9069024301 HW: 9069014500 Shop #: WSC 00000 000 00000 ASAM Dataset: 33 852 ROD: CRFT_EZE_33_851.rod (*) VCID: 020C34FA9589CC961D-8056
2 Faults Found: 90C1 - Emergency light activated; rotary light switch: implausible condition Test Complete - Stored 90C2 - Emergency light activated; for rotary light switch evaluation: voltage not correct Test Complete - Stored
------------------------------------------------------------------------------- Address B6: LT3 Steering Wheel Part No SW: 9065402545 HW: 9065402545 Shop #: WSC 00000 000 00000 ASAM Dataset: 72 257 ROD: CRFT_SML_72_257.rod (*) VCID: 081826D2B3B5E6C643-805C
End-------------------------(Elapsed Time: 02:34)--------------------------
