Leisure battery relay
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=94566
Printed Date: 28 Nov 20 at 05:04
Topic: Leisure battery relay
Posted By: wells01
Subject: Leisure battery relay
Date Posted: 04 Aug 20 at 12:57
I have a large leisure battery fitted under the passenger seat of my 03 lt35. It was charged via a voltage sensing relay which has failed so I have bought a heavy duty split charge relay which is triggered with a 12v switch feed. I cant work out where to take a ignition key switched 12v feed from though. I dont have a manual and cant find a wiring diagram.
Any ideas?
Many thanks.
