Merc VIto 16” Wheel Steel Advice
Forum Name: T3 Wheel help
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=94570
Printed Date: 31 Oct 20 at 12:58
Topic: Merc VIto 16” Wheel Steel Advice
Posted By: Mushroom_Gaz
Subject: Merc VIto 16” Wheel Steel Advice
Date Posted: 09 Aug 20 at 14:57
I have a 1985 VW Campervan. Wanting to go for raises suspension with steel rims and A/T tyres using:
Mercedes Vito 16” Wheels
P/N: 6394012602
ET54
Centre Bore: ???
6J x 16 H2
Questions:
1. Standard VW PDC 66.6?
2. What size spacers needed or best? ET54, read original VW Steels ET30 but original VW alloys ET39. So, 25/20/25mm spacers all out?
3. Hubcentric Spacers or not?
4. Spigot ring required?
5. Tapered or Radius Bolts required and length?
6. Will 205/80/r16 A/T be OK with standard suspension?
Many thanks   ...   Gary
