LT35 158 Cutting out under load
URL: http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=94591
Printed Date: 28 Nov 20 at 07:44
Topic: LT35 158 Cutting out under load
Posted By: Phaeton_Buggy
Subject: LT35 158 Cutting out under load
Date Posted: 12 Sep 20 at 21:13
Son's LT35 with 2.8? 158BHP Doesel 2004 keeps cutting out usually when under load, it will be pulling strong, then you ease of the throttle & then as you go back on the engine shuts down, if you switch off & back on again it fires up immediately & will run again. But it then may do it seconds later or hours later, it's just as though the ignition has just been switched off.
